Dynamic Blocks Forum
Array count?
26 REPLIES 26
Message 1 of 27
1624 Views, 26 Replies
Array count?
i have a parking block with array action.
i want to know how many parking do i have after using the array?
tried using placeholder of the distance, but i need somehow to divide the total.
maybe use formula.
thanks in advance
Array count?
maybe use formula.
thanks in advance
Labels (1)
26 REPLIES 26
Message 21 of 27
ojuris
ojuris
double click on mtext and then right click to field and Edit field
Message 22 of 27
h_s_walker
h_s_walker
That's the one I put in. You can delete it since @ojuris did a better one.
Howard Walker
Left Handed and Proud
Howard Walker
Message 23 of 27
in reply to: ojuris
that's what i get after double clicking on the MText
Message 24 of 27
h_s_walker
h_s_walker
As I said you can delete it, it's not needed, but if you want to edit the field. when in the mtext box right click on the number 1 and then EDIT FIELD should appear
Howard Walker
Howard Walker
Message 25 of 27
vinodkl
vinodkl
Hi @Anonymous
To edit the field or to look into the field inside mtext you need to first double click on the "MTEXT" which will let you edit the mtext and then double click again on the field inside the "MTEXT" to edit the field🙂
In the snapshot you have just double-clicked to edit the mtext.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Hi @Anonymous
Message 26 of 27
in reply to: vinodkl
hallelluya !!!!!!!! 🤗
thanks!!!!!
i succeed !!!!!!!!!
now i can explore fields
thanks!!!!!
i succeed !!!!!!!!!
Message 27 of 27
vinodkl
vinodkl
That's Great!!!😄
That's Great!!!😄
AutoCAD Inside the Factory
