Dynamic Blocks Forum
Array command error ...
7 REPLIES 7
Message 1 of 8
M_H_G_M_G
779 Views, 7 Replies
Hello every one
i have made a dynamic block and use ordinary array command
i have a problem that it array a block above my block and have an angle 90
how can i remove that useless block that arrayed
it don't be in consideration in auto-cad  and still no = 1
array command work correctly with me and it arrayed more blocks as i need but still there is one useless block above all blocks that arrayed ...
photos will explain what i mean
7 REPLIES 7
Message 2 of 8
hwalker
in reply to: M_H_G_M_G
Post the drawing so we can have a look at it
Howard Walker
Left Handed and Proud
Message 3 of 8
M_H_G_M_G
in reply to: hwalker
here you are sir ....
Message 4 of 8
hwalker
The problem as I see it is that you've already arrayed the items in the block. You shouldn't do that. You should add an array action, but never create the array in the block.
You need to go into every visibility state and EXPLODE the array by selecting the part ringed in the image below
Howard Walker
Message 5 of 8
M_H_G_M_G
Thanks sir
It isn't arrayed with the block
When I explode the array this useless block disappeared
It seems that there is an error in the program about that
Message 6 of 8
hwalker
I only selected the object on it's side (bottom left red ring) and as you can see the other item got selected as well (right red ring) and they are an array (top red ring). See the image below
Howard Walker
Message 7 of 8
M_H_G_M_G
Thanks sir
But try to explode it
It will disappear
What dis that mean?
Message 8 of 8
M_H_G_M_G
Hello every one
I have discovered the solution by luck
there is a layer AutoCAD  make it call "ADSK_ASSOC_ENTITY_BACKUPS"
and this part is in and AutoCAD automatically freeze this layer but I make thaw all layers and this layer appeared
the solution is to freeze this layer "ADSK_ASSOC_ENTITY_BACKUPS"
thanks every one that try to help me ...
Forma Design Contest
AutoCAD Beta
