Hello every one
i have made a dynamic block and use ordinary array command
i have a problem that it array a block above my block and have an angle 90
how can i remove that useless block that arrayed
it don't be in consideration in auto-cad and still no = 1
array command work correctly with me and it arrayed more blocks as i need but still there is one useless block above all blocks that arrayed ...
photos will explain what i mean
Solved by S_S_SS. Go to Solution.
Post the drawing so we can have a look at it
Howard Walker
The problem as I see it is that you've already arrayed the items in the block. You shouldn't do that. You should add an array action, but never create the array in the block.
You need to go into every visibility state and EXPLODE the array by selecting the part ringed in the image below
Howard Walker
I only selected the object on it's side (bottom left red ring) and as you can see the other item got selected as well (right red ring) and they are an array (top red ring). See the image below
Howard Walker
Hello every one
I have discovered the solution by luck
there is a layer AutoCAD make it call "ADSK_ASSOC_ENTITY_BACKUPS"
and this part is in and AutoCAD automatically freeze this layer but I make thaw all layers and this layer appeared
the solution is to freeze this layer "ADSK_ASSOC_ENTITY_BACKUPS"
thanks every one that try to help me ...
