Dynamic Blocks Forum
Angular Dimension Rotation
4 REPLIES 4
599 Views, 4 Replies
I want to have a dynamic block with a line that rotates using a rotation parameter set. I also want a angular dimension to follow that line and display the angle of that line.
Any ideas?
David
4 REPLIES 4
Have a look at this example
If I understand your example correctly it uses an Associative Angular Dimension (DimAssoc set to 2). The Associative Dimension follows the line on it's own accord and not using any Dynamic Parameters or Actions.
I thought of this right before your reply. And it appears to work as I needed it to.
Thanks for your help,
David
Yep thats correct glad you got it working, happy to help
perez7edmon
I am working on a dynamic block with the same requirements, however I would like to have the angular dimension to stay on one direction only (clockwise direction). The angular dimension should also be able to show angles of more than 180 degrees. I would be really grateful for your help
Forma Design Contest
AutoCAD Beta
