Aligning the rotating object along a path Autocad LT
Hi guys!
If found several solutions for the problem mentioned in title but with usage of lisps (like this). Unfortunately I'm using Autoacad LT with no possibility of using lisps. Is there any option of solving this only using dynamic block's commands?
Simplyfing my problem:
  • I have rectangle:1.png
  •  When I use array vertically/horizontally it works fine:
  • But when I pull it on some angle, I want it to rotate along the line. But it is not:
    Can I deal with it not using any lisps? Will be glad for any help 🙂
vinodkl
You can achieve the result with dynamic block with no usage of LISP(see attachment).
Will post the step by step procedure screencast of creating this block in awhile.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Hi vinodkl!
Yes, that is exactly what I was looking! Thank you! 😊
Nevertheless I will be extremely grateful if you manage to publish the step by step procedure screencast that you mentioned because still, when I am trying to use the command like you did it somehow it works differently.
vinodkl
I did create the screencast, but forgot to post it as I was busy with my work schedule 😅
Here it is
05ad1ba2-871f-4d43-8c5d-e256e5e8d4f4,640,710
I am afraid I can't see it 😔
vinodkl
Sorry about that. There is always problem with these screencast not displaying @Discussion_Admin  please look into this.
Amazing- great job! Have a nice day and thank you 😊
