Looking at Access_Point a Dynamic Block inside block editor:
ACCESSPOINTSIZE is an attribute that is linked to a User Defined Parameter in the Block Properties Table
via a BlockPlaceHolder reference
There is a block table grip that controls the block based on selection from that grip.
The visibility is AccessPointDisplay.
Looking at an instance of Access_Point:
Note:
AccessPointSize (a user defined parameter) &
ACCESSPOINTSIZE (an attribute)
in the properties display on the left.
Pressing the grip allows me to select a different Access Point Size:
Note:
AccessPointSize is now 228, however,
ACCESSPOINTSIZE is still 144
By entering the block editor for Access_Point and exiting, the attribute updates.
How do I get the attribute to update after the table call, without entering the editor?
Neither attsyc or block reset have any effect on this problem.
I believe that it has something to do with that we are accessing the default of the attribute.
Also changing visibilities while changing AccessPointSize does not update the Attribute.
Solved by hwalker. Go to Solution.
After a field has changed you need to do a REGEN for the change to show
Howard Walker
