Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
172 Views, 1 Reply
Viewer
Does anybody know of a viewer that will view a saved AutoCAD 3D drawing with hidden lines removed? If VoloView is the answer, how is this supported?
1 REPLY 1
You cannot save a DWG file with hidden lines 'removed'. You can set a viewport in your DWG to HIDEPLOT which has the effect you seek. And as long as you close your file with the LAYOUT in display, any DWG viewer, including Volo View, will see it as you did in AutoCAD. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
