BUG: cPlane creation Plane At Angle
cekuhnen
Mentor Mentor
cekuhnen
https://drive.google.com/file/d/0Byzv_NlyKp_2X3JUcXM0QWJiQms/view?usp=sharing
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
innovatenate
Autodesk Support
Autodesk Support
There is no requirement (or option) for a loft rail to maintain tangent continuity across it's length. To overcome this, try using a slightly different approach.
First, extrude the patch surfaces. The surface edges will help you to create tangent profiles in the loft command.
Next, mirror and inspect.
Below is a quick screencast demonstrating a potential solution for this (besides the one in the initial video).
http://autode.sk/1HLbvm1
I hope this helps!
Nathan Chandler
Principal Specialist
cekuhnen
ah yes true I over looked the fact that you can switch the profile rail order.
However imagine you have now at the end and start of your profiles a surface as well and you need to patch this in?
You rail edge then cannot be surface continuity besides G0.
Now one could say well then start building from the left and to the right or so. This example here is just a test to show
loft simply need G1 and G2 for Rail profiles.
Think about loft in Fusion also like a curve network.
Claas Kuhnen
innovatenate
Autodesk Support
Autodesk Support
True! That scenario presents a few more problems for the current capabilities in the loft command.
Below are a few Ideastation posts to Vote Up on this topic in case there are interested parties.
I also defer to the Advanced Modeling discussion around future capabilites and timing in the below thread.
http://forums.autodesk.com/t5/design-and-documentation/question-are-you-happy-with-fusion-surfacing-...
As for possible existing solutions, the Sculpt environment should be able to get you there-ish  with G2 continuity.
Nathan Chandler
cekuhnen
Yeah I am really looking forward to the advanced modeling abilities. Too bad this is will only be available next year or so.
Claas Kuhnen
