Autodesk Community Product Team Office Hours
Comment (3)
(0) Recommend
As part of our ongoing efforts to connect with you all about the ongoing redesign of the community, we have set up this Office Hour meeting. The office hours will allow you to connect directly with the Community Product Team & UX designers to ask questions about the redesign of the community.
Any community member can register; however, we have set a maximum limit of 16 people per call to ensure that the discussions remain meaningful and focused. Please only register if you are going to attend. If you can no longer attend, please reach out to @bukola_odunyemi directly so the slot can be opened for someone else.
Event details
3 Comments
Curtis_Waguespack
@o.briggs , @amanda.k
Reminder about the B/A labeling in the feedback announcement.
This is the 5th time I've mentioned this, the first 3 times received no response. Yesterday's office hours being the 4th.
In split testing we would refer to the control version A and the test version B.  Going from old B to new A, as it is stated in the announcement would be going backward, and this has caused some confusion and ridicule.
Yesterday Alodia confirmed that internally the teams are following the standard labeling where A is the old/control, and B is the new/test version.
I still see it listed backward this morning.
Can you please update the announcement to correct this?
Curtis_Waguespack
Also I have a typo in the above message and can not edit it. Not sure if that is as designed, but if that is not the intended behavior, then that  would be another bug to log.
amanda.k
This has been updated @Curtis_Waguespack, thank you. I see your note as well about being unable to edit for typos, and logged it.
Amanda Pruyn
Principal Community Liaison Manager
