Revit Hints and Hacks: Do you know where your Levels are?
Ever seen a file with what appears to be a nest of levels going every which way? Levels represent a plane, and the plane only shows up where it is drawn. If it does not cross through a view, it will not show up in that view. Levels also define where plans are set. Floor plans, ceiling plans, structural plans and area plans are all defined by a level. They do not have to have a plan related to them; they can just define a height for something like a parapet. Levels that define a view of any type show up blue and if double clicked on Revit will open that view. If the level head is black, then there are no views related to that level. They can also define boundaries for some Revit objects such as a wall that can be set to start at one level and go up to another. Let the height of either level change and the wall adjusts accordingly.
This example, although just a small building, shows how levels can get a bit out of control. Some of these may not be necessary but they could at least have been set up so it is not such a mess. The 3D view shows where each level’s plane is defined.
The elevations show the levels locations also.
Some of these levels may not be necessary and can just clutter the drawings. This is apparently a restaurant, but is it necessary to have level for “Bar Top” or “Table Top” set up? Is “Ceiling” a necessary level? Please tell me they are not setting up the ceiling based on that level.
Something else that can happen is that a level gets drawn in a section and then it only crosses a narrower section of the project. For example, the team has decided to place a level called “Rowlock” in the project. Joe placed one in the wall section he was working in.
Joe drew this from left to left to right and the company’s template has the head of the level to go to the second pick point. Joe also did not unselect the option to Make Plan View while drawing the level. The Plan View Types… show the plans that would have been created automatically.
Now Bob is also working in this model and he is in another wall section. He does not see Joe’s “Rowlock” level so he assumes that it has not been created. He then created “ROWLOCK” level and like Joe he also created plans to go along with his level.
There are now plans related to two different “ROWLOCK” or “Rowlock” levels in the project.
Another thing to consider is that in ever section or elevation that crosses those planes created by the level lines there will be clean up to put the level heads all to one side. This mistake is easy enough to fix in this small project but if this were a much larger project it can go unnoticed for a long time.
Now for the solution to all of this, quick and easy. Do not draw levels ever again.
If there is a need for a level use the Pick Line option instead of drawing a line and do this in an elevation where the true extents of the levels are shown, not in a section view. Doing this will have the level match the same boundaries as the one picked. The head of the level will match and be locked with the others. The extents of the level will match. Don’t forget to stop by the Options bar and set for plan views or not and also set the distance for the offset. When using Pick Line be sure to check which side of the line being picked to put the new level in the direction it is needed.
Much cleaner look and level heads will always be lined up together.
Donnia Tabor-Hanson aka CADMama
7 Comments
Thommy_
What is your opinion about using Maximize 3D Model Extents in such a case?
donnia.tabor-hanson
Well @Thommy_, I would have to say that can work for extending out levels that are drawn shorter than the over all levels. The only thing is that it cannot change where the level head goes if the level was drawn in the opposite direction from the original levels found in the template. That is the beauty of Pick Line to develop new levels and again let me stress to do this in a view where that is not cropped and the entire level line can be seen. My goal is to always have the levels with the head on the same side and going the same distance.
Thanks for the question, it is a valid one for sure. For that that would like to see more about this go here:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-M...
victor_vijeuKD42L
For me , Maximize 3D Model Extents works for Datum, but not for Levels Planes. In some projects i received, the Levels Planes were so way off , it didn't show in any plan, elevation or section views. I had to create a new 3D view, then stretch those planes a lot. The Levels Planes should automatically align to Scope Boxes or to Building Extents.
donnia.tabor-hanson
@victor_vijeuKD42L I like how you think about the Level Planes and how they "should" like up with Scope Boxes or Building Extents. Maybe we should put this on the wish list and vote it up.
hmunsell
I like the Pick Line hack, going to have to try that 😊
donnia.tabor-hanson
@hmunsell that is the only way to go!
hmunsell
I teach my A/MEP users to check, or uncheck, the Structural/Building Story options of the Level. If the level is not used for a Plan View, I have them UnCheck the Building Story option. That way only the Plan View levels have it checked. I then have a View Filter that can be set to not display levels with Building Story UnChecked.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
