Revit Hints & Hacks: Customize Your Double-click Settings
Customization can sometimes be very easy. The Double-click Settings make it easy for you to pick how you want Revit to react when you double-click on various items. Start by selecting the Options from the File tab. In the Options dialog box select the User Interface option. Select the Double-click Options:. This will bring up the Customize Double-click Settings dialog box.
Starting with the Double-click for the Element Type: for a Family, there are three options.
  • Edit Family
  • Do Nothing
  • Edit Type
The Sketched Element option for Double-click action also has three options.
  • Do Nothing
  • Edit Family
  • Edit Type
For Inside Views / Schedules on Sheets there are only two options.
  • Do Nothing
  • Activate View
For Outside Views on Sheets it has two options.
  • Do Nothing
  • Deactivate View
The next is Assemblies with three options.
  • Do Nothing
  • Edit Type
  • Edit Element
When it comes to Groups, there are three options.
  • Do Nothing
  • Edit Type
  • Edit Element
The last Element Type: is the Stairs with two options.
  • Do Nothing
  • Edit Element
Hope this is double good for you!
Donnia Tabor-Hanson aka CADMama
Revit Family Counselor
Twitter @DonniaTH
1 Comment
