Revit 2023: Swapping Views on Sheets
In Revit 2023, you can now swap a view that is on a sheet with another one via a contextual Ribbon command.  It is an easy way to switch views on a sheet instead of deleting the existing view and then having to drag/drop another view.
To use this feature:
  • Open a Revit project containing multiple views and sheets on views
  • Go to a sheet view and select a view on that sheet to swap
  • In the contextual Ribbon called Modify|Viewports, use the dropdown menu to swap to a different view
