In this masterclass, Bifrost Product Manager Marcus Nordenstam will teach you how to use Bifrost visual programming to create a disintegration effect on production assets with UV mapping, animation, and deformation.
In part one below, Marcus walks through detaching faces from a mesh.
Note: This masterclass assumes you are using Bifrost 2.1.0.0 or later, and also requires compounds from the “Rebel Pack”, which can be downloaded here: https://area.autodesk.com/downloads/rebel-pack-030/
Labels:
Related blog posts
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
