Using Boreholes to Modify Topo Surface
I am aware that the Geotechnical module allows you to create multiple stripping surfaces from borehole data. I would like to apply the borehole depths to a edit to an entire topographic surface created from a topographic survey for volume calculations for the entire site.
If the boreholes could be used to drop the topographic surface linearly between boreholes and extend out to the top boundary, that would be excellent. We could then use that surface to create a volume surface to calculate stripped quantities. Which would give us a much better estimate of our quantities.
~Andy
