Looking for something simpler than using an Intersection object to link profiles. Intersections are an awesome idea but I feel there is a ton of room for improvement.
1. Simple intersection, no corridor creation options, just click one alignment and then the other and the profiles are linked.
2. It would be nice if you could link profiles not lock, so that if you change the vertex in either profile view it changes the other, kind of annoying to go profile hunting every time I need to change the vertex. Or, even clicking on the intersection so you can change the elevation at that point through the properties menu.
3. Add the ability to turn off the default of 'Create or Specify offset alignments' to the Edit Command Settings for 'CreateIntersection'
~Andy
