Show only
Search instead for
Add the ability to disable the automatic renaming of corridor regions when changing assemblies. Even just a check box in the assembly dialogue box that says "do not change region name" or something along those lines would be great,
In my opinion, the textbox of the name of the Region should be the Description or an optional name as we can do with FL.
Currently, we can't have a name in blank (empty).
Moreover, next to the Region should show a number (read only) of the region from a particular baseLine. I mean, a new column called Number to show the number of the Region. If we add/remove a refion then it is renumbered autoautomatically.
