Pressure Pipe Fitting Display
Is it possible to have pressure pipe fittings display with outer/inner diameter lines and hatching display options just like the pipes that are connected to the fitting. I created blocks as a solution in the mean time (see attached jpg) but it would be good to have this as a default option in the program. This would apply to both plan AND profile views of the fittings.
3 Comments
jeffl
My question is why was the pressure network parts given such a high level of detail, while gravity parts are much simpler linework?  Does the extra detail make the drawing files heavier?
jacob.dwyer
110% yes. Lets have this.
Similar to this idea:
https://forums.autodesk.com/t5/civil-3d-ideas/show-pressure-network-tee-branches-as-actual-size-in-p...
I these both fall under the category of make pressure networks work properly.
hallgrimurmar
Yeeesssss!
I was so happy when I saw that there was an update on the pressure profile style.  An I was soooo disappointed when I saw that is was not working well, and even in some parts even worse that before.
