Pressure network structures and thrust blocks
It would be more advisable that pressure pipe networks could be integrated with structures and thrust blocks objects.
Nowadays the only way to insert a structure is to create a dadicated gravity pipe network only to insert the structure object and this seems to be not a very efficient workflow.
Regarding thrust blocks it is impossible to insert a parametric object and this is a major lack in Civil 3D.
Thank you
Francesco
1 Comment
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
