Pickbox window while swapping surface edges
Prior to Civil 3D 2025, you could drag a selection window over tinn surface lines during the swap edges command. This function does not appear to exist in 2025 and should be added back. When I have a surface contour generate along a tinn line, I cannot swap that edge unless I edit the surface style, turn off the contour display, then begin the swap edge command again.
1 Comment
TimYarris
Thank you for reporting this. This is a known issue that we are working on fixing for a future release of Civil 3D.
Rail Community
