Project Explorer - Export Object List Pane
It would be great to be able to export the Objects list pane to a single file (or tab for excel).  I can export that data either through quick export or object sets but to recreate the Objects List pane I would need to copy that data from each tab.
I can get similar data for Parcels if I use the 'Parcel_Area_in_CSV' report, but that doesn't include the parcel description which I need for my workflow.
This is something that seems like it would be easy to do but isn't.
Thanks.
2 Comments
TimYarris
Thank you for your idea. It appears Project Explorer breaks each parcel into a separate Excel tab. I assume your request is to export them all to a single tab (in the same layout as in Project Explorer)?
Yes, that is correct.  But not just for parcels, it appears that the results from that top list pane can only be exported individually, not collectively.  I can see workflows where I may want to export a list of my alignments, pipe networks, etc.
Thanks for all the work your team does.
