I use offset alignments often for my designs. But I find the lack of a "curve" transition type frustrating.
It seems the transition types were more designed with straight roads in mind. The current transition types work fine for straight road scenarios, but they don't work well when you want to carry and transition around a corner. All I need is a "curve" transition type.
I can get close to the design I need with the "curve-line-curve" type, but it is never correct because there is always a straight line in the curve that is not possible to remove. I usually have to set my offset alignments to Static rather than Dynamic to finish my designs, which defeats the point of having dynamic design.
Please add a Curve transition type.
![m_kingdon_1-1718232394709.png m_kingdon_1-1718232394709.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1375213i9428A2AF34CDF28C/image-size/medium?v=v2&px=400)
![m_kingdon_0-1718232359629.png m_kingdon_0-1718232359629.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1375212i930A621DAE30FFEB/image-size/medium?v=v2&px=400)
