This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
More information about the boolean failure in Civil 3D
When extracting solids between two surfaces or trying to union two Solids with UNION command, the below error may appear and the procedure is failed:
"The Boolean operation on solid and/or surface bodies failed. Modeling Operation Error: Error Code Number is 18027".
To overcome this issue, users have to do very tedious work to find which part of the surface or solid is problematic and edit it accordingly. Usually, this is a trial and error method that not always brings positive results.
It would be desired to have more information or some hints regarding where to look for an issue, e.g. similar when trying to HATCH a large area that is not closed - red circles show up on break spots.
The process of generating a solid from a corridor surface is going to be more and more common in the future in order to export them for coordination.
6 Comments
f_furger
I support this idea!
This problem I know only too well and it would be great to get more information from the system!
eliska.spackova
Absolutely yes!
Earthwork solids are significant part of collaboration. Unfortunatelly this extraction between two surfaces fails way too often.
gozdeekavas
I agree this idea. Also, ,if you split your corridor, you should check the start station for new region. If there is no difference (like 1 cm), you cannot extract solid between corridor surface and existing ground. I solve my problem this way.
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
JLSchmitz
Yes please.  This is so frustrating!  3 out of 4 surfaces extracted without a problem, now I've spent hours trying to troubleshoot the fourth one.  It's no more complex than the others.  I need solids for IFC export (BIM Project).  I'm pulling my hair out here 😞
SashaSecrier
Observer
In my case problem solved by change corridor frequency
Rail Community
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
