This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
HEC-RAS .sdf file
HEC-RAS .sdf file
HEC-HAS can export a .sdf geospatial file but does not open in Map 3D Fdo, it would be great give the ability to Map 3D read this file to support in Map and GIS. On the other hand Autodesk would also give C3D ability to export a Map 3D Sdf from a river and flood analisies with all calculated features
2 Comments
TerryDotson
Note that the file extension on HEC RAS files is actually ".RASexport.sdf" and it's contents are not intended to be a tradiional .SDF file format.  Open a notepad and drag/drop one of each into it, you will find the one from HEC RAS is very readable ASCII, the other what appears as a binary mess.
ramd401
Thanks. One more reason for the interoperability i have mentioned for Autodesk work as happens with other Civil 3D objects (pipes, surface, road, points, and parcels) so as to help the Management of the model with GIS skills.
Thanks again
Rail Community
