This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Allow the Volume Report to open up in EDGE browser for Civil 3D versions 2019 and above
Please have the Volume Report (from the Analyze tab) output generate an .html instead of an .xml that opens in Microsoft Edge as Internet Explorer has been discontinued. This issue is affecting thousands of users and needs to be addressed. Thank you!
There’s a hotfix for 2019 through 2022 that fixes the Volume Dashboard -> Cut/Fill Reports but not the Volume Reports.
13 Comments
glyn.evansPN8LB
Observer
I am very saddened that this feature no longer works. I find the volume reports are essential to the method I use in presenting and calculating my earthworks and other materials. This change has already cost me several days trying to find workarounds (no go) and will undoubtedly either add time to my calculations or leave me with not being able to present the same information to clients and PMs as before. Why this would not be fixed bewilders me.
TimYarris
Status changed to: Accepted
Thanks for posting this. We are aware of this issue and are researching a hotfix. We will post more information as we get further into development.
joantopo
This is extremely necessary. It´s very very annoying..
TimYarris
This hotfix should address the issue. If you are not able to use the Volume Report after installing the hotfix, please confirm and let me know.
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/7wNgmiBMHnG4W6peThv8CQ.html
joantopo
You could add new hotfix in "Autodesk Acces" for the future.
glyn.evansPN8LB
Observer
Unfortunately, this does not seem to work for me. I was using the “select material” style sheet, but using the “earthworks” one only brings up the IE tab page
For whatever reason, I cannot seem to even run this file.
I am thinking IF somehow I got the earthworks one to work, I could copy it to create the style sheet I used before, but still no luck.
This is a MASSIVE amount of extra work every time I have to update a design and recalculate materials 😞
TimYarris
@glyn.evansPN8LB , would you please log a support case for this issue? I'm able to get both style sheets to launch successfully on my machine's default browser. There might be something in your environment that is causing this issue for you.
https://www.autodesk.com/support/contact-support
glyn.evansPN8LB
Observer
Hi Tim. Ok, for some reason this morning, the cut fill report now does display. However, when I try to use the "Select Material" style sheet for the report, it only comes up with the cut fill like earthworks would produce. Maybe I need to edit the Select Material xsl file somehow. This is my material list, and I used to be able to get each station with each material volume etc in my report not just overall cut and fill.
Old reports would come out with same format as the earthworks but with my material info info like this
Station             Material                    End Area       Volume              **** Volume
glyn.evansPN8LB
Observer
I found the other files needed... Lets see if it works. 2023 worked with the earthworks style but 2021 gives me the iehelper page. I am testing 2023 now after replacing the two files I failed to notice before...
HAHAHA It works in 2023!!!! I will solve the 2021 iehelper page issue somehow on my end I think.
What an awesome day! THANK YOU TIM!
TimYarris
Glad it works for you, @glyn.evansPN8LB !
mramseur
I'm using AutoCAD Civil 3D 2022, and I just ran into the same problem for the first time when generating Quantity Volume Reports.  When it gets ready to generate external .html reports on Microsoft Edge, it just goes blank.  I'm able to generate volume tables (see screenshot below) for the time being but it won't generate volume reports since it upgraded to Microsoft Edge.  I did load up the latest hotfix and load them in the proper folder (see screen shot below) from the above links from but no success.  I also closed the Civil 3D program and opened up the file after downloading the hotfixes, but nothing happened.
Thanks.
TimYarris
Hi @mramseur ,
Sorry for the delayed reply. Have you logged this as a support case? If you've installed the appropriate hotfix, this shouldn't be an issue any longer.
mramseur
Thanks Tim.  I did download the latest hotfix .xsl files (like in the above select styles screen), but no success yet.  I sent a message to the support team at Autodesk.  I have the AutoCAD 2022.2.1 version by the way.
Thanks.
Rail Community
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
