Alignment Label shall include Label Segments
There is provision to add Element Label using the Following dialog:-
While alignment extended with new Elements, every time, need to add the element label manually using the above dialog.
It will be better if provision is added in the below Dialog, for Element Label too, To enable dynamic update.
This facility already available for Profile Elements.
6 Comments
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
Saranya_SV9DFL
It will be usefull if you update this in 2025
Nayan_Saikia
Community Visitor
This is essential as it helps eliminate the burden of manual input every time, which can occasionally be challenging.
srajeswaran39HUY
Observer
It will be usefull in the for the quick access.
ay9
Community Visitor
Community Visitor
it will increase the work efficiency.
brpadala
Community Visitor
Yes, It would be better if we see that update.
