Civil entity labels / Pipe labels
Civil entity labels take the coordinate system orientation. Please, consider adding in the PROPERTIES box an option to set text orientation/rotation with an angle value for labels in the dragged state.
2 Comments
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
doni49
Use case example:  I have used the "Line and Curve" option within the annotation dialog.  Sometimes I need drag the label away from the line.  If the view is rotated, the label is no longer rotated properly.  I end up exploding the label.  If the line changes, I have to REPLACE the label, drag it, and explode it AGAIN.
Answer Day
Rail Community
