Alignment editiong
Alignment editiong
If you have an alignment editor, it SHOULD edit any and all alignments. and that includes curves set with tangent sections only.  seems AutoDesk overlooked this problem.  so the only solutions are 1. erase the alignment and start over (#$%&*) 2. break the alignment and start over (again !@%$&*)
alignments are the backbone for every engineering job, would you agree?
therefore aligments will need to be available for editing, reviseing, changing or whatever term  you wish to label it.
currently, an alignment created using fixed curve is trash in my drawing.
any ideals or serious suggestions?
a way to convert the fixed to floating to allow easy edits?
1 Comment
troma
