IMG (Terrain) File To Civil 3D
There is a need to bring IMG (Terrain) files in to Civil 3D, so you cand use the surface data.
3 Comments
jkellogg
Community Visitor
IMG surface files are rather common these days and are gaining in popularity as a key element of many large datasets.  Use of IMG files in Civil 3D appears to require cumbersome conversions using other programs that handle IMG files innately... I agree that Civil 3D should be able to work directly with IMG files.
dgorsman
Is there a publicly shared data format document and/or API available?  Or would AutoDesk have to purchase the rights to do this?
pgpfleuger
The file format is currently supported in Autodesk InfraWork 360. It is also supported in ArcGIS 10.3.
Answer Day
Rail Community
