y of Imagery
y of Imagery
johan_badenhorst
y of Imagery
johan_badenhorst
I am currently working on a Civil 3D model that has images referenced into the file.  I occasionally see rough pixilation in the image background.  Also when plotting to both pdf or an HP plotter this rough pixilation appears in the completed plot, eg.
I have changed work station from a desktop to a Laptop Dell precision 7510.  I did not encounter this problem with the desktop PC.
Kindly suggest remedies.
Pointdump
Hi Johan,
Welcome to the Autodesk Forum.
Here's a couple of threads that might help:
http://forums.autodesk.com/t5/autocad-civil-3d-forum/2017-sp1-1/m-p/6549879/highlight/true#M311626
http://forums.autodesk.com/t5/autocad-civil-3d-forum/weird-graphics/m-p/6505373/highlight/true#M3094...
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
johan_badenhorst
Hi Dave
Thanks. Unfortunately I neglected to add that I am running Civil 3D 2016 with SP 3.
I'll see If I can uninstall SPs
Regards
Johan Badenhorst | Technical Specialist, Hydropower, Dams and Tunnels
SMEC South Africa
267 Kent Avenue, Ferndale, Johannesburg, South Africa, 2194
T +27 (11) 369 0833 | F +27 (11) 886 4589 | M +27 (82) 510 8327
[email protected] | www.smec.com | LinkedIn
____________________________________________________
SMEC SNOWY MOUNTAINS ENGINEERING CORPORATION
Local People. Global Experience.
Disclaimer: The information contained in this e-mail and any attachment file is confidential. It is intended for the addressee, and may not be used, reproduced, disclosed or distributed without SMEC's permission. SMEC accepts no liability for loss or damage (whether caused by negligence or not) resulting from the use of any attached files.
Please consider the environment before printing this email.
Pointdump
Johan,
The Service Packs are not a problem in 2016, just 2017.
Graphics are the biggest problem in AutoCAD right now. Usually whenever there's a problem, turning off Graphic Acceleration fixes it. but I don't know if that'll work in your case.
Dave
Dave Stoll
Las Vegas, Nevada
johan_badenhorst
Hi Dave
I tried turning off the hard ware acceleration, but the problem persists.
I vaguely recall solving a similar problem before by a complete uninstall followed by a clean install. Don't really want to do that though.
Regards
SMEC South Africa
johan_badenhorst
Hi Dave
The Customer support team identified the problem to be related to the installation of Hotfix 4 for AutoCAD 2016.  Once I uninstalled Hotfix 4 the problem was resolved.
Thanks for your assistance.
Regards
Johan
Pointdump
Hi Johan,
I'm glad you got it figured out.
Please mark your post #6 as the Solution so others can see how you fixed it.
Dave
Dave Stoll
Las Vegas, Nevada
