Hi there,
Have a good day,
I have a problem with using Civil 3D today, so I would like your assistance.
In my picture below,
I am working with Part Builder in civil 3D.
I created the SFD (Structure Frame Diameter) and SFH (Structure Frame Height) in Size Parameter but it is not displayed in Model Parameter.
What went wrong?
How can I receive it in Model Parameter?
Thank you all for your attention,
Not sure why this occurs, possible due to being a required / optional parameter.
To fix, create a dimension to control the size in model then add the sizes etc to the SFH etc as you would need.
Once you are happy and ready to use, open the created Xml file and change the constant parameter entry for the corresponding SFH (and others) to Calc (amend each ref for CCA# etc so it does not match another entry) then give the calc value as $SFH.
Remember if you open this in Part builder you will need to amend the Xml again to fix.
If this is a Bug, it wont be fixed as no ones supposed to be using this builder anymore.
They want you to Buy other software to use the software you already have, its a bit like a crack dealer does to kids.
Mike
Did you PARTCATALOGREGEN in civil3d afterwards
Joe Bouza
Hi Thưởng Bùi Như,
Welcome to the Civil 3D forum! Thanks for posting.
Thank you, @MikeEvansUK, for stepping in with a detailed suggestion.
@buinhuthuong , does Mike's solution help with your issue? If you believe this is a bug, I encourage you to contact Autodesk Support at Contact Support so that they can take a closer look into the issue. They'll have access to additional tools we don't have here in Support Communities.
If you need any additional assistance, feel free to ask.
If they helped solve your issue, consider hitting the "Accept Solution" button. This helps others searching for similar problems find the answer quicker. It also lets our community know which topics are resolved and which still need attention. Plus, it's a great way to show appreciation to the person who helped you!
Hi @lim.wendy,
I appreciate your support,
I will contact Autodesk to solve this issue.
Have a good day.
