Civil 3D Forum
Working with Part Builder - Need help to get some Model parameter
8 REPLIES 8
Message 1 of 9
buinhuthuong
345 Views, 8 Replies
Hi there,
Have a good day,
I have a problem with using Civil 3D today, so I would like your assistance.
In my picture below,
I am working with Part Builder in civil 3D.
I created the SFD (Structure Frame Diameter) and SFH (Structure Frame Height) in Size Parameter but it is not displayed in Model Parameter.
What went wrong?
How can I receive it in Model Parameter?
Thank you all for your attention,
Labels (2)
8 REPLIES 8
Message 2 of 9
buinhuthuong
in reply to: buinhuthuong
Is anybody able to help me? 🙄😭
Message 3 of 9
MikeEvansUK
Not sure why this occurs, possible due to being a required / optional parameter.
To fix, create a dimension to control the size in model then add the sizes etc to the SFH etc as you would need.
Once you are happy and ready to use, open the created Xml file and change the constant parameter entry for the corresponding SFH (and others) to Calc (amend each ref for CCA# etc so it does not match another entry) then give the calc value as $SFH.
Remember if you open this in Part builder you will need to amend the Xml again to fix.
If this is a Bug, it wont be fixed as no ones supposed to be using this builder anymore.
They want you to Buy other software to use the software you already have, its a bit like a crack dealer does to kids.
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 4 of 9
buinhuthuong
in reply to: MikeEvansUK
Hi @MikeEvansUK ,
Thank you for supporting,
I appreciate it.
Have a good day!
Message 5 of 9
Joe-Bouza
Did you PARTCATALOGREGEN in civil3d afterwards
Joe Bouza
Message 6 of 9
buinhuthuong
in reply to: Joe-Bouza
Yes, I did.
I used PARTCATALOGREGEN before creating the part list.
Message 7 of 9
lim.wendy
Hi Thưởng Bùi Như,
Welcome to the Civil 3D forum! Thanks for posting.
Thank you, @MikeEvansUK, for stepping in with a detailed suggestion.
@buinhuthuong , does Mike's solution help with your issue? If you believe this is a bug,  I encourage you to contact Autodesk Support at Contact Support so that they can take a closer look into the issue. They'll have access to additional tools we don't have here in Support Communities.
  1. Visit the 'Contact Support' page at https://www.autodesk.com/support/contact-support.
  2. Once there, please sign in to your account
  3. Select the 'Using and troubleshooting my software' option.
  4. Next, provide a detailed description of your issue or question.
  5. Click on 'See options,' and you will receive your subscription contact choices. You can either click 'Live Chat' to chat with an Autodesk support specialist or click 'Create a case' to send your question via email.
If you need any additional assistance, feel free to ask.
If they helped solve your issue, consider hitting the "Accept Solution" button. This helps others searching for similar problems find the answer quicker. It also lets our community know which topics are resolved and which still need attention. Plus, it's a great way to show appreciation to the person who helped you!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Message 8 of 9
buinhuthuong
in reply to: lim.wendy
Hi @lim.wendy,
I appreciate your support,
I will contact Autodesk to solve this issue.
Have a good day.
Message 9 of 9
buinhuthuong
So sad 😓😥
Rail Community
