Hi All,
I saved and exited out of my work. A few minutes later I opened the file to change something, and my work wont display. Even zooming to one of the surfaces, nothing in the model space or layout is showing up. All my layers are turned on and thawed.
My work shows up in ACAD however, so I'm not sure what's running in the background of Civil3D. Any suggestions are helpful!
Solved by Jeff_M. Go to Solution.
Not much to go on but try:
Plan > World
Visual Style to 2DWireframe
Turn off Hardware acceleration
Update Graphics Card drivers
Select all in problem drawing - Paste into new drawing from template.
Allen Jessup
CAD Manager - Designer
It sounds like the next best bet is to update the Graphics drivers. Have you tried turning off Hardware Acceleration?
Allen Jessup
sounds like something i did.
make sure your work is in model space and you are not looking in paper space.
if you do not have a title block or view port in paper space it is easy to miss things.
good luck,
nonbeard13
