Civil 3D Forum
Work won't Display
8 REPLIES 8
Message 1 of 9
LeighsTGGQ6
446 Views, 8 Replies
Work won't Display
Hi All,
I saved and exited out of my work. A few minutes later I opened the file to change something, and my work wont display. Even zooming to one of the surfaces, nothing in the model space or layout is showing up. All my layers are turned on and thawed.
My work shows up in ACAD however, so I'm not sure what's running in the background of Civil3D. Any suggestions are helpful!
8 REPLIES 8
Message 2 of 9
AllenJessup
in reply to: LeighsTGGQ6
Not much to go on but try:
Plan > World
Visual Style to 2DWireframe
Turn off Hardware acceleration
Update Graphics Card drivers
Select all in problem drawing - Paste into new drawing from template.
Allen Jessup
CAD Manager - Designer
Message 3 of 9
LeighsTGGQ6
in reply to: AllenJessup
Thanks for your reply. I have tried pasting into a new drawing template, which worked temporarily then found myself back at square one when re-opening the drawing.
I can view objects in the isolated object viewer, just not in the model space viewport.
Message 4 of 9
AllenJessup
It sounds like the next best bet is to update the Graphics drivers. Have you tried turning off Hardware Acceleration?
Allen Jessup
Message 5 of 9
sounds like something i did.
make sure your work is in model space and you are not looking in paper space.
if you do not have a title block or view port in paper space it is easy to miss things.
good luck,
nonbeard13
Message 6 of 9
santhoulakis
It could help if you posted your drawing here.
Message 7 of 9
LeighsTGGQ6
in reply to: santhoulakis
Good point, drawing is attached. Thanks.
Message 8 of 9
Jeff_M
Open the MapTaskPane, check the Map Base display setting, your dwg will then display the objects.
Message 9 of 9
LeighsTGGQ6
in reply to: Jeff_M
Thank you!
Rail Community
