Civil 3D Forum
*Warning* Multiply owned object, handle "206CF"
35 REPLIES 35
Message 1 of 36
39794 Views, 35 Replies
I am getting this warning as I try to save my drawing.  Not sure what it means.
My drawing file crashed (FATAL ERROR) before I was able to complete the save.  I did a MAPCLEAN followed by AUDIT, but still get the error message when trying to save.
I am using C3D 2011 with Windows 7.
Any ideas would be greatly appreciated.
35 REPLIES 35
Message 2 of 36
This usually fixes it
Enter in the command line: (entdel(handet"206CF"))
Repeat this for any other handles that crop up,
Nathan
Message 3 of 36
SethHall
Hi ignich-
Just as Nathan had suggested, that command will remove the object. For a bit more information about this error, please have a look at this blog post: http://beingcivil.typepad.com/my_weblog/2010/08/warning-multiply-owned-objects.html
Hope this helps!
Seth Hall
Product Owner
Model Builder
Message 4 of 36
in reply to: SethHall
Thank you.
Message 5 of 36
Lisa_Pohlmeyer
When I try the suggestion for the command line entry I get this:
Command: (entdel(handet"5154"))
; error: no function definition: HANDET
My errors were 5153 and 5154
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 6 of 36
Sinc
in reply to: Lisa_Pohlmeyer
Try (entdel (handent "5154"))
Sinc
Message 7 of 36
Lisa_Pohlmeyer
ding, ding, ding... we have a winner.  Ah, syntax, love it.  Thanks so much!
Lisa Pohlmeyer
Civil 3D User
Message 8 of 36
how did you find out the error #'s
I'm having the same issue after doing the initial Command:
(entdel(handet"22f29"))
sounds like i need the error # to fix the problem.
Message 9 of 36
Jeff_M
HANDENT not HANDET.....
Jeff_M, also a frequent Swamper
Message 10 of 36
in reply to: Jeff_M
thanks....i need to learn how to type betterSmiley Embarassed
Message 11 of 36
Raising the Dead:
OK, the fix listed, now does not seem to work for C3D 2013.  AutoCAD just replies "nil"
Anyone have another solution to this?
Message 12 of 36
Jeff_M
Does the MOO not get deleted?
What does (entget (handent "23BAE")) return?
Message 13 of 36
EDTROUT
in reply to: Jeff_M
Tags (1)
Message 14 of 36
msarqui
in reply to: Jeff_M
I am having the same problem.
The (entget (handent "blablabla"))  return "nil"
Autodesk!!!! Are you there??
Message 15 of 36
Jeff_M
in reply to: msarqui
Not necessarily, no. This is a peer to peer help forum for the most part. Yes, we do sometimes get a few of the Autodesk people to come through here. But if you want real help from them you must submit a support request through your subscription center or the product feedback page.
Can you post your drawing to see if someone here can help?
Message 16 of 36
in reply to: Jeff_M
I'm having the same problem. After I delete the entity though and run audit, the drawing crashes.
Message 17 of 36
Red.Hawk
in reply to: Sinc
Thank you sir. Smiley Happy
Message 18 of 36
doni49
in reply to: Jeff_M
Since the previous poster didn't do as requested and post the actual dwg file, I'll do so here.
Command: _QSAVE
 *Warning* Multiply owned object, handle "A4A7"
 *Warning* Multiply owned object, handle "A4A6"
 *Warning* Multiply owned object, handle "A4A5"
Command:
Command:
Command: (entdel (handent "5154"))
; error: bad argument type: lentityp nil
Command: (entdel (handent "5153"))
EDIT:  I forgot to ask this but instead of JUST DELETING the offending object(s), is there a way to repair them or at least explode them to 3d polylines (assuming they're featurelines) so that I can recreate them?  At a very minimum, I'd need to know which objects they are.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 19 of 36
Jeff_M
in reply to: doni49
Don, I am not seeing that error message in your file, using C3D 2016. Also, your (entdel...) lines don't look right. You have to input the actual handle that says it's multiply owned:
(entdel (handent "A4A7")) would be correct based on the outpout you show.
Message 20 of 36
doni49
in reply to: Jeff_M
That's odd.  I'm also using C3D 2016 here (SP1).  I've seen this error previously in 2012 & 2014 too.
I copy/pasted the lisp code from the "answer" posted above.  I guess it never dawned on me that I needed to change it to the actual handle(s).  Smiley Embarassed
Any thoughts on the second part of the question (the "EDIT")?
Don Ireland
Rail Community
