*Warning* Multiply owned object, handle "206CF"
Message 1 of 36
I am getting this warning as I try to save my drawing.  Not sure what it means.
My drawing file crashed (FATAL ERROR) before I was able to complete the save.  I did a MAPCLEAN followed by AUDIT, but still get the error message when trying to save.
I am using C3D 2011 with Windows 7.
Any ideas would be greatly appreciated.
Replies (35)
Message 2 of 36
This usually fixes it
Enter in the command line: (entdel(handet"206CF"))
Repeat this for any other handles that crop up,
Nathan
Message 3 of 36
SethHall
Hi ignich-
Just as Nathan had suggested, that command will remove the object. For a bit more information about this error, please have a look at this blog post: http://beingcivil.typepad.com/my_weblog/2010/08/warning-multiply-owned-objects.html
Hope this helps!
Seth Hall
Product Owner
Model Builder
Message 4 of 36
Thank you.
Message 5 of 36
Lisa_Pohlmeyer
When I try the suggestion for the command line entry I get this:
Command: (entdel(handet"5154"))
; error: no function definition: HANDET
My errors were 5153 and 5154
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 6 of 36
Sinc
Try (entdel (handent "5154"))
Sinc
Message 7 of 36
Lisa_Pohlmeyer
ding, ding, ding... we have a winner.  Ah, syntax, love it.  Thanks so much!
Lisa Pohlmeyer
Civil 3D User
Message 8 of 36
how did you find out the error #'s
I'm having the same issue after doing the initial Command:
(entdel(handet"22f29"))
sounds like i need the error # to fix the problem.
Message 9 of 36
Jeff_M
HANDENT not HANDET.....
Message 10 of 36
thanks....i need to learn how to type betterSmiley Embarassed
Message 11 of 36
Raising the Dead:
OK, the fix listed, now does not seem to work for C3D 2013.  AutoCAD just replies "nil"
Anyone have another solution to this?
Message 12 of 36
Jeff_M
Does the MOO not get deleted?
What does (entget (handent "23BAE")) return?
Message 13 of 36
EDTROUT
Message 14 of 36
msarqui
I am having the same problem.
The (entget (handent "blablabla"))  return "nil"
Autodesk!!!! Are you there??
Message 15 of 36
Jeff_M
Not necessarily, no. This is a peer to peer help forum for the most part. Yes, we do sometimes get a few of the Autodesk people to come through here. But if you want real help from them you must submit a support request through your subscription center or the product feedback page.
Can you post your drawing to see if someone here can help?
Message 16 of 36
I'm having the same problem. After I delete the entity though and run audit, the drawing crashes.
Message 17 of 36
Red.Hawk
Thank you sir. Smiley Happy
Message 18 of 36
doni49
Since the previous poster didn't do as requested and post the actual dwg file, I'll do so here.
Command: _QSAVE
 *Warning* Multiply owned object, handle "A4A7"
 *Warning* Multiply owned object, handle "A4A6"
 *Warning* Multiply owned object, handle "A4A5"
Command:
Command:
Command: (entdel (handent "5154"))
; error: bad argument type: lentityp nil
Command: (entdel (handent "5153"))
EDIT:  I forgot to ask this but instead of JUST DELETING the offending object(s), is there a way to repair them or at least explode them to 3d polylines (assuming they're featurelines) so that I can recreate them?  At a very minimum, I'd need to know which objects they are.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 19 of 36
Jeff_M
Don, I am not seeing that error message in your file, using C3D 2016. Also, your (entdel...) lines don't look right. You have to input the actual handle that says it's multiply owned:
(entdel (handent "A4A7")) would be correct based on the outpout you show.
Message 20 of 36
doni49
That's odd.  I'm also using C3D 2016 here (SP1).  I've seen this error previously in 2012 & 2014 too.
I copy/pasted the lisp code from the "answer" posted above.  I guess it never dawned on me that I needed to change it to the actual handle(s).  Smiley Embarassed
Any thoughts on the second part of the question (the "EDIT")?
Don Ireland
