Civil 3D Forum
Viewport Layer issue
11 REPLIES 11
Message 1 of 12
500 Views, 11 Replies
Very strange problem.
I made a view port (actually a bunch) and then selected it and moved it to the correct layer. Now when I select the viewport it shows it's on the correct layer. However, if I use the LAYMCUR command it makes the original layer the viewport was on, current. When I plot it also pulls the plot style from the original layer the viewport was on.
11 REPLIES 11
Message 2 of 12
AllenJessup
Have you tried to Audit the drawing?
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 12
in reply to: AllenJessup
Yes
Message 4 of 12
Super annoying because I have my title block on the same layer the viewport was originally created on. So I can't just change that layer to no plot or I lose my whole title block. I'd like to avoid re-creating the viewports since I'll never be able to get them all lined up perfectly (or at least it will be a pain in the **** to get them precise again).
Message 5 of 12
AllenJessup
If you copy the viewport with 0,0 displacement does it still have the same problem? If not you can copy them and erase the originals.
Allen
Allen Jessup
Message 6 of 12
Genius, I will try that now. I did try creating new VPs on the correct layer to begin with and they worked correctly.
Message 7 of 12
Yes, they still have same problem. Going to try copytolayer.
Message 8 of 12
AllenJessup
If Copy doesn't work. Maybe CopyToLayer?
Allen
Allen Jessup
Message 9 of 12
Success! Copytolayer worked.
Message 10 of 12
AllenJessup
Great. I'd still like to know what caused the problem. I'd think it was an error in the Layer Table. But if Audit didn't fix it I don't know what would.
Allen
Allen Jessup
Message 11 of 12
troma
Was it just a viewport, or a viewport clipped with a polyline?
Is it possible the viewport was on one layer and the polyline on the other?
Mark Green
Working on Civil 3D in Canada
Message 12 of 12
in reply to: troma
It was a polygonal viewport that I created on one layer and moved to another. I try to make all my viewports polygonal to avoid having to clip them later if shape changes. I've run into the problem you are describing and have had to re-create viewports, thus I don't like clipped viewports.
Rail Community
