Very strange problem.
I made a view port (actually a bunch) and then selected it and moved it to the correct layer. Now when I select the viewport it shows it's on the correct layer. However, if I use the LAYMCUR command it makes the original layer the viewport was on, current. When I plot it also pulls the plot style from the original layer the viewport was on.
Solved by AllenJessup. Go to Solution.
Have you tried to Audit the drawing?
Allen
Allen Jessup
CAD Manager - Designer
Super annoying because I have my title block on the same layer the viewport was originally created on. So I can't just change that layer to no plot or I lose my whole title block. I'd like to avoid re-creating the viewports since I'll never be able to get them all lined up perfectly (or at least it will be a pain in the **** to get them precise again).
If you copy the viewport with 0,0 displacement does it still have the same problem? If not you can copy them and erase the originals.
Allen
Allen Jessup
If Copy doesn't work. Maybe CopyToLayer?
Allen
Allen Jessup
Great. I'd still like to know what caused the problem. I'd think it was an error in the Layer Table. But if Audit didn't fix it I don't know what would.
Allen
Allen Jessup
Mark Green
Working on Civil 3D in Canada
