Vertical profile co-ordinates
M_c3d
Advisor Advisor
Message 1 of 12
M_c3d
Hi all,
Query has come in from a contractor asking if we can provide co-ordinates for the start and end of curves on the vertical profile long section.
I had a look through the vertical geometry options and couldn't see any way.
Any ideas?
Thanks!
Replies (11)
Message 2 of 12
MMcCall402
You should be able to label these locations with coordinates in the plan view with a reference text component for the profile geometry within an alignment label style.
New:  I may have read that wrong ... my brain went to vertical curve start and end cordinates.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 3 of 12
MMcCall402
Reference text component for an alignment within a Horizontal Geometry profile label.  That should do it.
Mark Mccall
CAD Mangler
Message 4 of 12
tcorey
Starts and ends of horizontal curves or vertical curves?
"Provide coordinates..." In a list? As labels in a drawing?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 5 of 12
M_c3d
Hi @tcorey @MMcCall402 vertical profiles, i.e. vertical curves
They were looking for co-ordinates within the profile bands.
Message 6 of 12
MMcCall402
Ok, this is do-able, pseudo band looking text.
Make a vertical curve label style(s). in it make two reference text components for an alignment showing the northing and easting coordinates. Anchor one to the Anchor Curve Start Dimension and the other to the End Dimension. Label the profile, select them and give them the reference alignment name in the properties window.  At the bottom of the properties window in a place to set their dimension anchor. Set this anchor location to coincide with the band location.
Mark Mccall
CAD Mangler
Message 7 of 12
M_c3d
Hi @MMcCall402
I've created this however it only gives the high point of the curve co-ordinates at either end;
Message 8 of 12
MMcCall402
Those locations are the start and end points of the vertical curves, yes?
Mark Mccall
CAD Mangler
Message 9 of 12
M_c3d
Message 10 of 12
MMcCall402
I thought that was what you were looking for.
Can you show us what you need and we can figure out if and how to get it.
Mark Mccall
CAD Mangler
Message 11 of 12
M_c3d
Hi @MMcCall402
Yes that is what I'm needing.  The vertical profile label needs to show the start and end co-ordinates of the curve (i.e. in plan view setting out of the actual curve on site.).
The previous image gives duplicate co-ordinates and actually relates to the crest of the curve, i.e. the high point, rather than the start and end point of the curve.
Thanks.
Message 12 of 12
wfberry
You have the beginning and ending stations of the vertical curves along the alignment.  That should be easy enough to get the coordinates.
Bill
