Vehicle Tracking Query
dbanaszak
dbanaszak
I am a long time user of AutoTurn, but the Vehicle Tracking in Civil3D isn't quite the same. I have established a centerline with which to create my truck template, and it creates a template that allows me to adjust the centerline to ensure clearances on my site. What I want to do now is drive the truck template along the centerline and drop a copy of it in certain locations to ensure all of the truck is in a safe location free from other cross traffic. Any hints as to how I can do this with Vehicle Tracking? Thanx
rosie_lucas1
Hello @dbanaszak ,
Have you had time to review the information from the link provided by @Tomislav.Golubovic? Did you find anything that might have helped you and answer your question?
If yes, please share with the community so other members who come across a similar issue may benefit from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie | Community Manager
dbanaszak
I define a centerline that creates my driven path from end to end. What I want to do is drag the truck template along that centerline and drop the template at specific spots along that centerline. I sed to be able to do it with AutoTurn, but I'm not sure how to do it now. Thanx
Tomislav.Golubovic
Yep, which is what's in the link I provided.
Do you want to position the vehicle on the path? - https://help.autodesk.com/view/VEHTRK/2022/ENU/?guid=GUID-27BAAA9F-4B94-49C0-B723-8B7B7B8DC0F2
dbanaszak
I'm not seeing it. I don't even see the Position Vehicle dialog in 2026. I want to drive the vehicle on the path similar to how Animate does, but under my cursor control. Then have it freeze at certain points along the path and leave a copy of the vehicle showing its articulation at that point.
andrew.schroeder
@dbanaszak If I understand you correctly, this might be what you're after:
Check out my submitted ideas, and vote if you think they'd be useful:
-> Alignment Regions for Station Range-Based Styles in Civil 3D
-> Add Conflict Resolution Options When Pasting One Surface into Another
