ObjectARX 2026 SDK
ObjectARX 2026 SDK
cturlington
ObjectARX 2026 SDK
cturlington
The above download did not appear to provide access to "Autodesk.Civil.DatabaseServices.dll," and "Autodesk.Civil.dll."  Are they still provided in the 2026 Civil 3D download? It does not appear that they are.  These are the only two that I am missing.
Any suggestions or response is greatly appreciated.
ecfernandez
Hi @cturlington, it seems the download you are mentioning is not showing up in your post. Could you please share that again?
Regards
Camilo Fernández
P.Eng | Transportation
LinkedIn
cturlington
All,
The download was the SDK files from online.  However, I have since learned that particular download is not needed.  And in fact, the 2026 C3d software does not provide the above-mentioned reference files, as I suspected.  However, the key reference files are these:
accoremgdd.dll
acmgd.dll
AeccDBMgd.dll
AecBaseMgd.dll
Civil.dll
acdbmgd.dll
found in C:\programs\Autodesk\AutoCAD 2026\, C:\programs\Autodesk\AutoCAD 2026\ACA, and C:\programs\Autodesk\AutoCAD 2026\C3D.
