Unsolved posts challenge: Week Feb 17th, 2025
lim.wendy
Alumni Alumni
Message 1 of 1
lim.wendy
Check out last week's most popular posts that have yet to receive an accepted solution. If you have a solution for any of these topics, we encourage you to share it. Remember, marking a post as an "Accepted Solution" helps the wider community find answers more quickly. Thank you for your contributions!
Date Posted
Topic
Message Sentiment
20-Feb-25
Ready to throw them all out the window...
MIXED
21-Feb-25
Displaying 3D models / viewports in a Civil 3D drawing = massive lag
MIXED
20-Feb-25
Looking for a way to automate drafting of curb & gutter
NEUTRAL
17-Feb-25
Converting classificaiton in Recap to layers/Objects  in AutoCAD Civil 3D
NEUTRAL
19-Feb-25
Cross Sections for Vertical Surfaces
NEUTRAL
17-Feb-25
Infoworks ICM :Out of memory
NEUTRAL
17-Feb-25
Alignment Masking
NEUTRAL
17-Feb-25
Designing Scale Problem while Pasting Objects to Original Coordinates
NEUTRAL
22-Feb-25
subassembly composer-Connecting the ditch to the surface boundary
NEUTRAL
20-Feb-25
EPGS codes
NEUTRAL
21-Feb-25
SHP file data (point ID) shows up one computer, not another
NEUTRAL
19-Feb-25
Earthworks for Mining
POSITIVE
21-Feb-25
Analyze water runoff in existing water stream
NEUTRAL
17-Feb-25
Update civil3d dynamo
NEGATIVE
21-Feb-25
Convert COGO points to regular "text" points
NEUTRAL
20-Feb-25
MAPIINSERT issue
NEUTRAL
21-Feb-25
Sub assembly composer insertionPT
NEUTRAL
17-Feb-25
Base Files with different CS transformations
NEUTRAL
21-Feb-25
Table layout
NEUTRAL
19-Feb-25
DYNAMO: Setting Property Value By Name
NEUTRAL
20-Feb-25
Rim elevations won't update until toggling Automatic Surface Adjustment off and back on.
NEUTRAL
17-Feb-25
What is "Shoulder Breakover" selection?
NEUTRAL
18-Feb-25
CREAR SUBASSEMBLY PARA  CORTE  Y QUE SE UNA A LOS PUNTOS DE PROYECCCION DE CORTE Y RELLENO
POSITIVE
20-Feb-25
C3D makes a sound each time I change colour on layers
NEGATIVE
19-Feb-25
Trying to Extend Alignment
MIXED
18-Feb-25
Problema con Escalas Entre Modelo y Presentación
NEGATIVE
17-Feb-25
XREF items not following .ctb
NEUTRAL
16-Feb-25
Drawing sheet creation along a highway corridor
NEUTRAL
17-Feb-25
Need Offset Assembly to change Basepoint of subassembly
MIXED
20-Feb-25
QTO Manager
NEUTRAL
21-Feb-25
Unsolved posts challenge: Week Feb 10th, 2025
20-Feb-25
How do I add BeginShoulderRollover station?
NEUTRAL
20-Feb-25
ArcGIS Coordinate System unavailable
NEUTRAL
20-Feb-25
What hydrology software are you using now?
NEUTRAL
20-Feb-25
Two aliases will not commit
POSITIVE
20-Feb-25
C3D dwg template brings data referenced pipe network structures into the dwg with the wrong style.
NEGATIVE
20-Feb-25
Projections updated in old drawing each time it's opened
NEUTRAL
17-Feb-25
Assembly Baseline Point vs Insertion Point.
NEUTRAL
21-Feb-25
How to Connect a Pressure Pipe to a Gravity Structure Valve?
NEUTRAL
21-Feb-25
Part Builder for Caps
NEUTRAL
19-Feb-25
LaneFromTaperedMedian2 - assign profile to right lane
NEUTRAL
21-Feb-25
how you can create a pavement assembly without assigning materials
NEUTRAL
20-Feb-25
modify parcel report
20-Feb-25
Adjusting surfaces towards points in Civil 3D
NEUTRAL
22-Feb-25
2D→3D コンクリート舗装のサーフェス作成
20-Feb-25
Unable to set Pressure Network Catalog
21-Feb-25
Profile views - Create 1 then move the viewports around or just make a bunch of profiles?
MIXED
20-Feb-25
Estilos de alinhamentos e pontos não estão aparecendo na lista
NEUTRAL
22-Feb-25
Grading Optimization Isn't Showing Up
NEGATIVE
20-Feb-25
Adding "Feet" after distance in Metes and Bounds Report
NEUTRAL
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Replies (0)
