Trying to Extend Alignment
drwhoar
drwhoar
Hey Folks,
Here's an odd issue. Got an alignment that I want to extend. I drew the lines and arcs I need and used the editor to add them to the end of the alignment. So far, so good. The alignment shows visually as being all of the pieces, but the stationing only extends a portion of the additional parts. If I edit the geometry of the alignment, it only shows the first seven segments! I removed the sub-elements from the end of the stationing to the end of the alignment, re-drew them, re-attached them, and - nothing. Still won't extend.
Any ideas on what's wrong?
Sean_Fahey_10
Can you share a screenshot of your alignment and/or possibly send an xml of the alignment for users to attempt a solution for you.
RobertEVs
Be sure that if you add extensions to your alignment that if you tie-into the beginning Station 0+0 that the line does NOT go from there out but must come into your alignment there. Same with the end of an alignment. Must connect to the last station then go OUT from there. Has to keep direction to label stationing
