Analyze water runoff in existing water stream
Areas "A" and "B" are sloped to the water stream flowing through the middle. I am planning to use pipe culverts at locations "1" and "2". I need to know if the depth of the existing stream is sufficient to keep these two areas from flooding. How can I do it using SSA or INFODRAINAGE in civil 3d? what are the work steps?
(Assuming that there is no water flow through the stream under normal conditions, we need to know whether the water in these two sections will flood during a rainfall event.)
Thank you
