Two questions about 'Create Alignment From Object'
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm attempting to create an alignment from a polyline I just drew. I'm struggling with how C3D decides to create the alignment's direction.
That is, I picked a starting point then an ending point for my polyline, and I want the alignment 0+00 beginning station to be at that same starting point from drawing my polyline.
First, when I get to the step where I'm prompted "Press enter to select alignment direction (or Reverse)", I do not see the direction arrow cue on the alignment.
I've seen this happen off-and-on in the past. What controls whether that arrow cue appears? I thought it was related to Layer zero being on/off, so I made sure it was on before attempting to create the alignment.
Second, it is not using the first point of my polyline as the beginning of the alignment, it is using the last point as the beginning, so my alignment stationing is reversed. And because the arrow cue doesn't appear, I don't realize that until too late (profiles created, profile view, etc).
tl;dr: What controls the visibility of the alignment direction arrow when creating an alignment from object? What determines which endpoint C3D uses to be 0+00 station when creating alignment from object?
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
