Xref override layer display
sconroy
sconroy
I'm not sure how to rectify this, but in my layers property manager, I keep seeing xref overrides and the supposedly overriden layers are highlighted and are quite distracting (see below)
The problem is that the layers are not actually overridden. How do I stop these layers from being displayed this way, or how can I 'reconcile' these layers?
samir_rezk
Hi @sconroy
You need to disable the layer property override background color in the layer settings dialog box. To access the setting, you should see a Cog/Gear wheel icon at the top right corner of the layer properties manager palette.
hope this helps,
Samir Rezk
Technical Support Specialist
sconroy
that'll do it. I don't know why all of a sudden this was an issue as I definitely didn't set this feature, but glad to know I can get rid of it.
Thanks!
