I have a file which was originally Autodesk blocks which I converted to Softdesk blocks which I now need to convert into COGO points.
I know that there is the "Replace Softdesk Point Block" command, and I have used it with success in the past. Unfortunately it doesn't seem to be working anymore.
All of my point groups are visible.
All of my layers are turned on.
Am I missing something here?
I have attached a smaller version of what I am working with, if anyone has any ideas they want to try.
None of the data in the file contains Softdesk Point Blocks, there just plain blocks. If you have a .mdb (LDD) you could get the data from that.
Rick Jackson
Survey CAD Technician VI
Those are not softdesk pionts. Try to use the Dataextraction command to export what you created to a comma delimited file and then import the ascii file into C3D.
@Anonymous @rl_jackson How can I tell the difference between regular blocks and Softdesk blocks in my drawing?
Using the Data Extraction command worked, thank you!
Regular blocks could be a water valve, sewer manhole and fire hydrant. Softdesk blocks are topo point blocks created by the Softdesk program back in time.
