Civil 3D Forum
TIN Surface
4 REPLIES 4
592 Views, 4 Replies
TIN Surface
We have survey information of a bridge and terrain in the same file.
I am almost sure there is no way to have one surface because the bridge is overlapping the terrain.
Some way I can have one surface of this information? Please see the pic.
4 REPLIES 4
tcorey
The quick answer is No, you cannot have overlapping surface data in a Civil 3D TIN Surface.
You should maintain the original ground as a surface and model the bridge. Displaying both together will look good. You can create a surface for your bridge, but leave it separate from the og. If you have InfraWorks, modeling bridges is very quick and design transfers to Civil 3D easily.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
in reply to: tcorey
Thanks! I am doing exactly that!
I wanted to be sure if that is a new feature in 2021 version, but it is not!
Thanks!
in reply to: tcorey
Why are these triangles missing or going wrong way, because the breaklines are crossing?
Udo_Huebner
Yes, a few 3D Polylines are overlapping but with different elevations. You cannot create vertical triangles (for walls). Simply move the lower 3D Polylines at least 0.001 m outside, then the surface rebuilds as expected.
Gruß Udo Hübner (CAD-Huebner)
Rail Community
