Surface
Surface
Surface
Hi, does anyone know what "aligning edges" mean when creating or updating a surface?
It took forever for it to load for some reason.
Thank you!
Its refering to the triangle edges that form a TIN surface. It has to be taking long either because there is a lot of points to be triangulated or if your are creating it with contours, then the size of the triangles is very small for higher accuracy.
Thank you very much!
Youre welcome!
