Civil 3D Forum
Surface fusion
2 REPLIES 2
_Basher_
83 Views, 2 Replies
Surface fusion
Hello everyone.
I have a project in which i have to concrete a surface on which there are existing foundations. I have created a surface with the slopes i need for water drainage.
Now i need to merge these surfaces to be able to perform watershed analysis
First of all i try to create a new surface ("Fusion") by joining the 2 surfaces.
As you can see, the existing foundations have disappeared, but the perimeter slopes have been included.
The next idea i have is to obtain the minimum distance between the 2 surfaces (new vs existing) in order to apply a boundary and obtain a new surface with the foundations i need and then try to merge. The problem is that there is a part where they dont intersect.
Any idea how i can do this?
Labels (1)
2 REPLIES 2
tcorey
in reply to: _Basher_
You said "As you can see, the existing foundations have disappeared...."
I can't see that. Can you post a screenshot of Option3 surface? That's the one with the building pads?
Are you able to post the dwg file?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
brian.strandberg
Keep in mind when you paste surfaces, and the surfaces overlap, the last one wins.  So if there is an area you don't want to be included in the paste you will need to remove it from the surface.
I spend time on this forum because I enjoy Civil 3d and getting your likes.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Civil 3d to Street View: https://youtu.be/8Ima00-vLQA
Vote for My Idea:
https://forums.autodesk.com/t5/civil-3d-ideas/favorite-coordinate-zones/idi-p/12790928
Rail Community
