Civil 3D Forum
Surface and Boundaries
2 REPLIES 2
275 Views, 2 Replies
I know you are able to create a surface within Civil 3D, however, I would like to know if you can see different boundaries within this surface. For example, I have created a surface for a site and I would like to know if there's a way that I can define where the roads are on the surface. This way, when looking at it in 3D, I can clearly see where the roads are compared to everything else on the surface.
2 REPLIES 2
neilyj666
I would probably make two copies of the surface and in the first copy add a boundary(ies) for the roads and give it a certain style. Use this road surface as a hide boundary ( non destructive) for the second copy and give it a new style.  Then in 3d the roads should be identifiable.
I do this a lot in Infraworks and use coverages to identify various features
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Have you tried adding a masking to the areas of the surface you want to highlight?
Rail Community
